iPi Recorder User's Guide
Revision as of 09:09, 26 April 2016 by Vmaslov (Talk | contribs)
Note: This article is under construction and will be published in a few days. Meanwhile refer to v2 documentation: http://wiki.ipisoft.com/IPi_Recorder_User%27s_Guide
General UI Layout
UI layout
