iPi Recorder User's Guide
General UI Layout
- Home. Starting screen which provides access to all functions of the program.
- Setup. Adjust device settings before recording.
- Background. Evaluate background before recording.
- Record. Set recording options and start recording.
- Recording. Displays recording statistics.
- Play. Playback of iPiVideo files.
- Edit. Editing of iPiVideo files and export to AVI format.
Many views contain a grid of screens, each displaying data from an individual device. For instance, video frames from a camera or 3D orientation of motion controller.
When you hover over a device screen with a mouse, some controls and information specific to this device are displayed in an overlay (4). For example, a button to display this device screen in a full screen mode.
Home View
- Refresh allows the program to discover newly connected devices without restarting.
- Add Controller makes a connection between motion controllers and PC.
- Camera Types shows whether specific camera types are supported on this system, and what should be done to add this support.
On the right there is a list of recently recorded or played videos. Just click on an item to open this video for playback and/or editing. You can also press the Browse button to select a file to open with the file dialog.
