iPi Recorder User's Guide
General UI Layout
- Home. Starting screen which provides access to all functions of the program.
- Setup. Adjust device settings before recording.
- Background. Evaluate background before recording.
- Record. Set recording options and start recording.
- Recording. Displays recording statistics.
- Play. Playback of iPiVideo files.
- Edit. Editing of iPiVideo files and export to AVI format.
Many views contain a grid of screens, each displaying data from an individual device. For instance, video frames from a camera or 3D orientation of motion controller.
When you hover over a device screen with a mouse, some controls and information specific to this device are displayed in an overlay (4). For example, a button to display this device screen in a full screen mode.
Home View
- Refresh allows the program to discover newly connected devices without restarting.
- Add Controller makes a connection between motion controllers and PC.
- Camera Types shows whether specific camera types are supported on this system, and what should be done to add this support.
On the right there is a list of recently recorded or played videos. Just click on an item to open this video for playback and/or editing. You can also press the Browse button to select a file to open with the file dialog.
Recording Workflow
Setup
Setup view allows to adjust general and individual camera settings before recording. You can:
- Select working video mode
- Select microphone and audio mode
- Adjust number of cameras displayed in a grid row to optimize screen space usage
- Reorder devices within a grid.
- To place a device to a specific position, drag it's screen to this position. You can also throw away unneeded device if it has been selected by mistake, simply by dragging away it's screen.
- Tip: For convenience, it is recommended to place cameras in the same order they go around the capture area – either clockwise, or counter-clockwise. However, you're free to use any order you like.
- Select display layout for depth sensors screens when both depth and color are present.
- Set global properties for a group of similar devices, if there are any.
- Example of such property is Darkening for Calibration for PS Eye cameras. Global properties are found in corresponding group in the ribbon.
- Examples of such properties include brightness and contrast for color cameras, and elevation angle for Kinects. To access individual device properties, press the PROPERTIES button in the device's screen overlay.
- Tip: Program remembers settings values and restores them on the next run automatically.
