iPi Recorder User's Guide
Revision as of 12:26, 26 April 2016 by Vmaslov (Talk | contribs)
Note: This article is under construction and will be published in a few days. Meanwhile refer to v2 documentation: http://wiki.ipisoft.com/IPi_Recorder_User%27s_Guide
General UI Layout
UI Layout
Home View
Home View
  • Add Controller makes a connection between motion controllers and PC.
  • Camera Types shows whether specific camera types are supported on this system, and what should be done to add this support.
Tip: The program remembers your last selection. Thus, if you have not disconnected devices since the last run, the selection will most probably restore automatically.
On the right there is a list of recently recorded or played videos. Just click on an item to open this video for playback and/or editing. You can also press the Browse button to select a file to open with the file dialog.
Recording Workflow
Setup
Setup View
Setup view allows to adjust general and individual camera settings before recording. You can:
  1. Select working video mode
  2. Select microphone and audio mode
  3. Adjust number of cameras displayed in a grid row to optimize screen space usage
  4. Reorder devices within a grid.
  5. Select display layout for depth sensors screens when both depth and color are present.
  6. Set global properties for a group of similar devices, if there are any.
    Example of such property is Darkening for Calibration for PS Eye cameras. Global properties are found in corresponding group in the ribbon.
  7. Set properties of individual cameras.
    Examples of such properties include brightness and contrast for color cameras, and elevation angle for Kinects. To access individual device properties, press the PROPERTIES button in the device's screen overlay.
Background
Background View
Record
Recording
Recording Results
Editing and Export
Additional Resources
