T-Pose for Depth Sensors
Revision as of 08:49, 14 December 2016 by Andrew (Talk | contribs)
T-Pose
As soon as recorder starts, go to the capture area and stand in a T-pose. After that you can act desired motions.
If you make several takes of one actor, we recommend to strike a T-pose in the beginning of each take.
Tip: We use tracking data from modern depth sensors for workflow improvements. You can get most of it if you follow recommendations described here.
