Animation Export
- 1 Animation Export
- 2 Motion Transfer
- 3.1 MotionBuilder
- 3.2 3D MAX Biped
- 3.3 Maya
- 3.4 FBX
- 3.5 COLLADA
- 3.6 LightWave
- 3.7 SoftImage|XSI
- 3.8 Poser
- 3.9 DAZ 3D
- 3.10 iClone 3
- 3.11 Valve Source Engine SMD
- 3.12 Valve Source Filmmaker
- 3.13 Blender
- 3.14 Cinema4D
- 3.15 Evolver
- 3.16 Second Life
- 3.17 Massive
- 3.18 IKinema WebAnimate
- 3.19 Jimmy|Rig Pro
Animation Export
- Select Export tab
- Select output file format
Motion Transfer
Other rigs
- Select Export tab
- Humanik Maya 2012 Part 6
- Produce text or binary file
iClone 3
Select Blender target character on Export tab and export animation to BVH format.
