Multiple Actors
Revision as of 02:44, 13 August 2018 by Andrew (Talk | contribs)
Pro Edition, supports multi-person tracking with the following limitations:
  • Currently two or three actors tracking is available in the public release.
  • To track multiple actors, at least 3 Sony PS Eye cameras per actor are required
    • It's recommended to use 4 Sony PS Eye cameras per actor. Having more cameras minimizes actor's mutual occlusion and improves tracking reliability.
    • For two actors you can use 3 Kinect sensors
    • For simple dual actor actions when actors are rarely close to each other you can use 4 — 5 RGB cameras or even two depth sensors.
  • Multi-person tracking is available only in Pro Edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
For depth sensors:
Cameras Configuration
The main requirement is to minimize self- and mutual occlusions of actors. In general, cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use minimum recommended number of cameras (or less) then all actions should be planned in such a way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to capture two actors handshake with just two depth sensors:
Scene Configuration Example
T-pose
It's convenient but not strongly required all actors to stay in T-pose at one and the same time as far from each other as possible (actors should be fully visible in maximum number of cameras).
T-poses of Actors
Processing
How many actors?
First actor parameters
Second actor parameters
Active actor on UI
  • For each actor:
Tracking Tab Controls
Motion Controllers
You can use up to 3 motion controllers per actor for:
  • left hand
  • right hand
  • head
Animation Export
Export
Sample Video and Project
Here you can find sample videos and projects for three actors captured with ten Sony PS3 Eye cameras.
PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png  PSEyeFlat.png
Calibration Sequence
three_actors_10_cams_catch_and_throw_calib.iPiVideo
436 MByte
three_actors_10_cams_catch_and_throw_calib.iPiCalib
363 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select three_actors_10_cams_catch_and_throw_calib.iPiCalib file downloaded on the previous step.
    • select three_actors_10_cams_catch_and_throw_calib.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate button;
      • the height of first camera over ground plane is about 1.41 m
Performance Sequence
three_actors_10_cams_catch_and_throw_action.iPiVideo
333 MByte
three_actors_10_cams_catch_and_throw_action.iPiMotion
2.63 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select three_actors_10_cams_catch_and_throw_action.iPiMotion file downloaded on the previous step.
