iPi Recorder User's Guide
General UI Layout
- Home. Starting screen which provides access to all functions of the program.
- Setup. Adjust device settings before recording.
- Background. Evaluate background before recording.
- Record. Set recording options and start recording.
- Recording. Displays recording statistics.
- Play. Playback of iPiVideo files.
- Edit. Editing of iPiVideo files and export to AVI format.
Home View
- Refresh allows the program to discover newly connected devices without restarting.
- Add Controller makes a connection between motion controllers and PC.
- Camera Types shows whether specific camera types are supported on this system, and what should be done to add this support.
On the right there is a list of recently recorded or played videos. Just click on an item to open this video for playback and/or editing. You can also press the Browse button to select a file to open with the file dialog.
Recording Workflow
Setup
Setup view allows to adjust device and screen settings before recording.
You can:
- Select working video mode
- Select microphone and audio mode
- Adjust number of cameras displayed in a grid row to optimize screen space usage
- Reorder devices within a grid.
- To place a device to a specific position, drag it's screen to this position. You can also throw away unneeded device if it has been selected by mistake, simply by dragging away it's screen.
- Tip: For convenience, it is recommended to place cameras in the same order they go around the capture area – either clockwise, or counter-clockwise. However, you're free to use any order you like.
- Select display layout for depth sensors screens when both depth and color are present.
- Set global properties for a group of similar devices, if there are any.
- Example of such property is Darkening for Calibration for PS Eye cameras. Global properties are found in the Shared Settings group in the ribbon.
- Examples of such properties include brightness and contrast for color cameras, and elevation angle for Kinects. To access individual device properties, press the Properties button in the device's screen overlay.
- Tip: Program remembers settings values and restores them on the next run automatically.
Background
Record
- None
- Uncompressed data. The lowest load of CPU, and the highest load of storage.
- Background subtraction
- Lossless computational-inexpensive compression. Provides compression ratio in the range 2..10 approximately. A trade-off between CPU and storage.
- JPEG (for color only)
- Lossy computational-expensive compression. Provides compression ratio up to 100 and more, depending on value of the Quality setting. The highest load of CPU, and the lowest load of storage.
- Note: Use with caution for color cameras. Lossy compression reduces the quality of the image, and may lead to more tracking errors. If you are forced to use it due to limited disk space/speed, leave the quality value at considerably high level. We recommend 70 and more.
- How well an actor is distinguished from the background. For instance, if shirt color is close to the color of walls, then an actor may blend with the background and this will spoil tracking.
- Whether background has changed substantially and needs to be re-evaluated. Another indication of this fact is a low percentage of background area in camera statistics. It is highlighted with red in this case.
The Refresh button reninitializes all the devices without leaving to the Home view. This helps in case of temporary hardware glitches.
Also, the ribbon contains controls related to distributed recording. Their usage is described in a separate article.
Editing and Export
iPi Recorder is capable of simple editing of recorded .iPiVideo files as well as exporting data to regular media files. To use these features switch to the Edit view when a video is open for playback.
Editing is essentially saving a subset of originally recorded data to the same or to another .iPiVideo file. There are two options to define a subset of video data to be used for save/export, which you can use separately or combined:
- Exclude data from some of the devices.
- Click on a device screen to select/unselect data from this device. Or use commands in the ribbon to perform group selection operations.
- Tip: This option is particularly useful when one of the cameras spoils tracking but you don't want to throw away the whole video. For example, the camera was moved during recording so its position in the scene is not accurate. Or the colors in that camera differ too much from other cameras.
- Select a range of frames.
- Use controls in the Trimming group in the ribbon to set range boundaries.
- Tip: This option is useful for trimming useless data from both ends of the video. If a video contains multiple takes, it may be convenient to save them into separate .iPiVideo files.
After you have selected the data to use, hit the Save button to replace the original file, or Save As to save the data to another file.
Video export produces an .avi video file from color streams of selected cameras or depth sensors. Besides selecting devices to export (and a frame range if needed) you should take care of a couple of other things:
- Video codec used to encode a resulting video.
- When multiple screens are selected, choose how they are composed into a single video frame.
Press the Export Video button to select a destination file and run the export.
You can also export audio data only to a .wav audio file.
