Cameras and Accessories
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
The only downside of PlayStation Eye is its lack of tripod mounting screw. Possible solutions:
Cables
Tripods
Video Card
iPi Mocap Studio relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. Any DirectX 11 capable video card is compatible with iPi Motion Capture. As a minimum, you need DirectX 10 capable GPU with support of DirectCompute.
Please be aware that desktop GPUs are dramatically faster than laptop GPUs (due to apparent thermal constraints in laptop PCs). Laptops with switchable graphics should be configured to run iPi Mocap Studio on a discrete (high-performance) GPU.
USB controllers
USB hubs
Known compatibility issues
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device behave the same as PrimeSense Carmine 1.08 with this controller. |
| ASUS Xtion (Live) | VIA VT6212L (USB2) | Frame drops of color picture in 640x480@30 (depth + color). | |
| PrimeSense Carmine 1.08 | NEC µPD720200 (USB3) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VT6212L (USB2) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VL800(USB3) | Frame drops, reduced frame rate, freezes in depth + color modes. | Stable work in depth only modes. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. | |
| Sony Playstation Eye | VIA VT6212L (USB2) | Great number of frame drop in 640x480@60 mode. | 2 cameras can work smoothly at lower FPS (up to 640x480@50). |
