Single Azure Kinect Samples
Revision as of 03:20, 27 September 2019 by Andrew (Talk | contribs)
Here you can find sample videos and projects captured by single Azure Kinect depth sensor in two different modes: narrow view (NFOV) and wide view (WFOV).
NFOV mode
Sample performance video file with "physical exercises" movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single-k4a-nfov.iPiVideo
550 MByte
single-k4a-nfov.iPiMotion
2 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single-k4a-nfov.iPiMotion file downloaded on the previous step.
    • select single-k4a-nfov.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
    • then you can process the video.
WFOV mode
single-k4a-wfov.iPiVideo
254 MByte
single-k4a-wfov.iPiMotion
0.6 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single-k4a-wfov.iPiMotion file downloaded on the previous step.
    • select single-k4a-wfov.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
