Dual Azure Kinect Samples
Revision as of 09:45, 27 September 2019 by Andrew (Talk | contribs)
Here you can find sample videos and projects captured by two Azure Kinect depth sensors in two configurations (180-degrees and 90-degrees) and two modes (NFOV — narrow view and WFOV &mdahs; wide view).
180-degrees Configuration
NFOV mode
Light Marker Calibration
dual-k4a-180-nfov-calibration-light-marker.iPiVideo
411 MByte
dual-k4a-180-nfov-calibration-light-marker.iPiCalib
191 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
    • select dual-k4a-180-nfov-calibration-light-marker.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate Based on Light Marker button;
    • after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
    • now you can visually check the quality of the resulted point cloud.
Board Calibration
dual-k4a-180-nfov-calibration-board.iPiVideo
503 MByte
dual-k4a-180-nfov-calibration-board.iPiCalib
116 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-calibration-board.iPiCalib file downloaded on the previous step.
    • select dual-k4a-180-nfov-calibration-board.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate Based on Board button;
"Walking" Performance
Sample performance video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
dual-k4a-180-nfov-walk.iPiVideo
240 MByte
dual-k4a-180-nfov-walk.iPiMotion
0.5 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-walk.iPiMotion file downloaded on the previous step.
    • select dual-k4a-180-nfov-walk.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: dual-k4a-180-nfov-calibration-light-marker.iPiCalib
      • Gender = Male
      • Height = 1.75 m
    • then you can process the video.
"Physical Exercises" Performance
Sample performance video file with physical exercises movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
dual-k4a-180-nfov-exercises.iPiVideo
927 MByte
dual-k4a-180-nfov-exercises.iPiMotion
2 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-exercises.iPiMotion file downloaded on the previous step.
    • select dual-k4a-180-nfov-exercises.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.72 m
WFOV mode
dual-k4a-180-wfov-calibration-light-marker.iPiVideo
985 MByte
dual-k4a-180-wfov-calibration-light-marker.iPiCalib
158 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
    • select dual-k4a-180-wfov-calibration-light-marker.iPiVideo file downloaded before;
Board Calibration
dual-k4a-180-wfov-calibration-board.iPiVideo
932 MByte
dual-k4a-180-wfov-calibration-board.iPiCalib
80 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-calibration-board.iPiCalib file downloaded on the previous step.
    • select dual-k4a-180-wfov-calibration-board.iPiVideo file downloaded before;
dual-k4a-180-wfov-walk.iPiVideo
530 MByte
dual-k4a-180-wfov-walk.iPiMotion
0.5 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-walk.iPiMotion file downloaded on the previous step.
    • select dual-k4a-180-wfov-walk.iPiVideo file downloaded before;
    • choose the following file as scene parameters: dual-k4a-180-wfov-calibration-light-marker.iPiCalib
      • Gender = Male
      • Height = 1.72 m
"Floor Rolls" Performance
Sample performance video file with floor rolls and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
dual-k4a-180-wfov-rolls.iPiVideo
1970 MByte
dual-k4a-180-wfov-rolls.iPiMotion
2 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-rolls.iPiMotion file downloaded on the previous step.
    • select dual-k4a-180-wfov-rolls.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
90-degrees Configuration
NFOV mode
dual-k4a-90-nfov-calibration-light-marker.iPiVideo
604 MByte
dual-k4a-90-nfov-calibration-light-marker.iPiCalib
194 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
    • select dual-k4a-90-nfov-calibration-light-marker.iPiVideo file downloaded before;
Board Calibration
dual-k4a-90-nfov-calibration-board.iPiVideo
756 MByte
dual-k4a-90-nfov-calibration-board.iPiCalib
96 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-calibration-board.iPiCalib file downloaded on the previous step.
    • select dual-k4a-90-nfov-calibration-board.iPiVideo file downloaded before;
dual-k4a-90-nfov-exercises.iPiVideo
574 MByte
dual-k4a-90-nfov-exercises.iPiMotion
1.2 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-exercises.iPiMotion file downloaded on the previous step.
    • select dual-k4a-90-nfov-exercises.iPiVideo file downloaded before;
    • choose the following file as scene parameters: dual-k4a-90-nfov-calibration-light-marker.iPiCalib
      • Gender = Male
      • Height = 1.72 m
WFOV mode
dual-k4a-90-wfov-calibration-light-marker.iPiVideo
852 MByte
dual-k4a-90-wfov-calibration-light-marker.iPiCalib
140 KByte
dual-k4a-90-wfov-walk.iPiVideo
504 MByte
dual-k4a-90-wfov-walk.iPiMotion
0.6 MByte
