Dual Azure Kinect Samples
Here you can find sample videos and projects captured by two Azure Kinect depth sensors in two configurations (180-degrees and 90-degrees) and two modes (NFOV — narrow view and WFOV — wide view).
180-degrees Configuration
NFOV mode
Light Marker Calibration
| ↓ Download video file ↓ dual-k4a-180-nfov-calibration-light-marker.iPiVideo 411 MByte |
| ↓ Download calibration file ↓ dual-k4a-180-nfov-calibration-light-marker.iPiCalib 191 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
- select dual-k4a-180-nfov-calibration-light-marker.iPiVideo file downloaded before;
- switch to Calibration tab and push Calibrate Based on Light Marker button;
- after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
- now you can visually check the quality of the resulted point cloud.
Board Calibration
| ↓ Download video file ↓ dual-k4a-180-nfov-calibration-board.iPiVideo 503 MByte |
| ↓ Download calibration file ↓ dual-k4a-180-nfov-calibration-board.iPiCalib 116 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-calibration-board.iPiCalib file downloaded on the previous step.
- select dual-k4a-180-nfov-calibration-board.iPiVideo file downloaded before;
- switch to Calibration tab and push Calibrate Based on Board button;
"Walking" Performance
Sample performance video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual-k4a-180-nfov-walk.iPiVideo 240 MByte |
| ↓ Download project file ↓ dual-k4a-180-nfov-walk.iPiMotion 0.5 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-walk.iPiMotion file downloaded on the previous step.
- select dual-k4a-180-nfov-walk.iPiVideo file downloaded before;
- choose Action project type;
- choose the following file as scene parameters: dual-k4a-180-nfov-calibration-light-marker.iPiCalib
- Gender = Male
- Height = 1.75 m
- then you can process the video.
"Physical Exercises" Performance
Sample performance video file with physical exercises movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual-k4a-180-nfov-exercises.iPiVideo 927 MByte |
| ↓ Download project file ↓ dual-k4a-180-nfov-exercises.iPiMotion 2 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-nfov-exercises.iPiMotion file downloaded on the previous step.
- select dual-k4a-180-nfov-exercises.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.72 m
WFOV mode
| ↓ Download video file ↓ dual-k4a-180-wfov-calibration-light-marker.iPiVideo 985 MByte |
| ↓ Download calibration file ↓ dual-k4a-180-wfov-calibration-light-marker.iPiCalib 158 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
- select dual-k4a-180-wfov-calibration-light-marker.iPiVideo file downloaded before;
Board Calibration
| ↓ Download video file ↓ dual-k4a-180-wfov-calibration-board.iPiVideo 932 MByte |
| ↓ Download calibration file ↓ dual-k4a-180-wfov-calibration-board.iPiCalib 80 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-calibration-board.iPiCalib file downloaded on the previous step.
- select dual-k4a-180-wfov-calibration-board.iPiVideo file downloaded before;
| ↓ Download video file ↓ dual-k4a-180-wfov-walk.iPiVideo 530 MByte |
| ↓ Download project file ↓ dual-k4a-180-wfov-walk.iPiMotion 0.5 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-walk.iPiMotion file downloaded on the previous step.
- select dual-k4a-180-wfov-walk.iPiVideo file downloaded before;
- choose the following file as scene parameters: dual-k4a-180-wfov-calibration-light-marker.iPiCalib
- Gender = Male
- Height = 1.72 m
"Floor Rolls" Performance
Sample performance video file with floor rolls and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual-k4a-180-wfov-rolls.iPiVideo 1970 MByte |
| ↓ Download project file ↓ dual-k4a-180-wfov-rolls.iPiMotion 2 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-180-wfov-rolls.iPiMotion file downloaded on the previous step.
- select dual-k4a-180-wfov-rolls.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
90-degrees Configuration
NFOV mode
| ↓ Download video file ↓ dual-k4a-90-nfov-calibration-light-marker.iPiVideo 604 MByte |
| ↓ Download calibration file ↓ dual-k4a-90-nfov-calibration-light-marker.iPiCalib 194 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
- select dual-k4a-90-nfov-calibration-light-marker.iPiVideo file downloaded before;
Board Calibration
| ↓ Download video file ↓ dual-k4a-90-nfov-calibration-board.iPiVideo 756 MByte |
| ↓ Download calibration file ↓ dual-k4a-90-nfov-calibration-board.iPiCalib 96 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-calibration-board.iPiCalib file downloaded on the previous step.
- select dual-k4a-90-nfov-calibration-board.iPiVideo file downloaded before;
| ↓ Download video file ↓ dual-k4a-90-nfov-exercises.iPiVideo 574 MByte |
| ↓ Download project file ↓ dual-k4a-90-nfov-exercises.iPiMotion 1.2 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-nfov-exercises.iPiMotion file downloaded on the previous step.
- select dual-k4a-90-nfov-exercises.iPiVideo file downloaded before;
- choose the following file as scene parameters: dual-k4a-90-nfov-calibration-light-marker.iPiCalib
- Gender = Male
- Height = 1.72 m
WFOV mode
| ↓ Download video file ↓ dual-k4a-90-wfov-calibration-light-marker.iPiVideo 852 MByte |
| ↓ Download calibration file ↓ dual-k4a-90-wfov-calibration-light-marker.iPiCalib 140 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-wfov-calibration-light-marker.iPiCalib file downloaded on the previous step.
- select dual-k4a-90-wfov-calibration-light-marker.iPiVideo file downloaded before;
| ↓ Download video file ↓ dual-k4a-90-wfov-walk.iPiVideo 504 MByte |
| ↓ Download project file ↓ dual-k4a-90-wfov-walk.iPiMotion 0.6 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual-k4a-90-wfov-walk.iPiMotion file downloaded on the previous step.
- select dual-k4a-90-wfov-walk.iPiVideo file downloaded before;
- choose the following file as scene parameters: dual-k4a-90-wfov-calibration-light-marker.iPiCalib
- Gender = Male
- Height = 1.75 m
