Sample Video and Project (two depth sensors)
Here you can find sample videos and animations captured by two MS Kinect 2 (Kinect for XBox One) depth sensors with the aid of Distributed Recording.
Calibration Sequence
| ↓ Download video file ↓ dual_kinect2_calibration_short.iPiVideo 550 MByte |
| ↓ Download calibration file ↓ dual_kinect2_calibration_short.iPiCalib 242 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect2_calibration_short.iPiCalib file downloaded on the previous step.
- select dual_kinect2_calibration_short.iPiVideo file downloaded before;
- switch to Calibration tab and push Calibrate Based on Light Marker button;
- after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
- now you can visually check the quality of the resulted point cloud.
"Walking" Performance Sequence
Sample performance video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual_kinect2_walking.iPiVideo 104 MByte |
| ↓ Download project file ↓ dual_kinect2_walking.iPiMotion 371 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect2_walking.iPiMotion file downloaded on the previous step.
- select dual_kinect2_walking.iPiVideo file downloaded before;
- choose Action project type;
- choose the following file as scene parameters: dual_kinect2_calibration_short.iPiCalib
- Gender = Male
- Height = 1.75 m
- then you can process the video.
Exported "Walking" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
"Floor Rolls" Performance Sequence
Sample performance video file with floor rolls movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual_kinect2_floor_rolls.iPiVideo 438 MByte |
| ↓ Download project file ↓ dual_kinect2_floor_rolls.iPiMotion 1.26 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect2_floor_rolls.iPiMotion file downloaded on the previous step.
- select dual_kinect2_floor_rolls.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
Exported "Floor Rolls" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
"Spin Jump" Performance Sequence
Sample performance video file with spin jump movement and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ dual_kinect2_spin_jump.iPiVideo 71.8 MByte |
| ↓ Download project file ↓ dual_kinect2_spin_jump.iPiMotion 324 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect2_spin_jump.iPiMotion file downloaded on the previous step.
- select dual_kinect2_spin_jump.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
Exported "Spin Jump" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
More Samples
- Old (previous) samples can be found here.
- Sample videos and animations captured by two ASUS Xtion Live sensors can be found on the following page: Sample Video and Project (two ASUS Xtions).
