Sample Video and Project (single depth sensor)
Revision as of 09:04, 27 September 2019 by Andrew (Talk | contribs)
Note: Sample videos captured by single Azure Kinect depth sensor can be found here: Single Azure Kinect Samples.
Here you can find sample videos and animations captured with the aid of single MS Kinect 2 (Kinect for XBox One) depth sensor.
"Walking" Sequence
Sample video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_walking.iPiVideo
114 MByte
single_kinect2_walking.iPiMotion
750 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_walking.iPiMotion file downloaded on the previous step.
    • select single_kinect2_walking.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
    • then you can process the video.
Exported "Walking" Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Droid Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
"Chair" Sequence
Sample video file with sitting-on-chair movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_chair.iPiVideo
115 MByte
single_kinect2_chair.iPiMotion
865 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_chair.iPiMotion file downloaded on the previous step.
    • select single_kinect2_chair.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "Chair" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
"Exercises" Sequence
Sample video file with physical-exercises movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_exercises.iPiVideo
198 MByte
single_kinect2_exercises.iPiMotion
1.3 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_exercises.iPiMotion file downloaded on the previous step.
    • select single_kinect2_exercises.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "Exercises" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
"a la Twist" Sequence
Sample video file with a la twist movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_twist.iPiVideo
49.2 MByte
single_kinect2_twist.iPiMotion
391 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_twist.iPiMotion file downloaded on the previous step.
    • select single_kinect2_twist.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "a la Twist" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
More Samples
  • Old (previous) samples can be found here.
