Recording Video from Depth Sensor Environment
Revision as of 08:32, 30 September 2019 by Andrew (Talk | contribs)
Environment
Configuration Azure Kinect (WFOV mode) Azure Kinect (NFOV mode)
Kinect 2 (Kinect for Xbox One)
Kinect (1st gen.)
Single Depth Sensor
7 by 5 feet = 2 by 1.5 meters
8 by 5 feet = 2.5 by 1.5 meters
10 by 10 feet = 3 by 3 meters
2 Depth Sensors
(90-degrees config.)
7 by 7 feet = 2 by 2 meters
8 by 8 feet = 2.5 by 2.5 meters
2 Depth Sensors
(180-degrees config.)
12 by 7 feet = 3.5 by 2 meters
16 by 8 feet = 5 by 2.5 meters
20 by 10 feet = 6 by 3 meters
3+ Depth Sensors
12 by 12 feet = 3.5 by 3.5 meters
16 by 16 feet = 5 by 5 meters
20 by 20 feet = 6 by 6 meters
Maximum capture area is about 7 by 7 feet ( = 2 by 2 meters), for all sensor models and configurations.
The pictures below will help you to understand possible capture area and required space. Dimensions are different for Azure Kinect, Kinect 2 (Kinect for Xbox One) and Kinect 1st gen. sensors due to different field of view.
Azure Kinect in NFOV mode and Kinect 2 for Windows (Kinect for Xbox One)
Kinect 2 (Kinect for Xbox One) sensors and Azure Kinect sensors in NFOV mode (narrow-view mode) have very close view angles (less than Azure Kinect in WFOV mode has, but greater than Kinect 1st gen):
Side view
Top view
Wide-view mode (WFOV mode) of Azure Kinect has extremely wide view angle:
Side view
Top view
Note: But please be aware that quality of depth map is better in narrow-view mode (NFOV mode). For this reason, if you have enough space, it is recommended to use NFOV mode for Azure Kinect sensors.
First Generation Depth Sensor or Orbbec Astra (Pro)
If you're using outdated 1st generation depth sensor like Kinect v1 or Orbbec Astra (Pro) sensor which is almost the same as 1st gen. depth sensor:
Side view
Top view
