Streaming to Unity
Revision as of 07:49, 2 October 2019 by Vmaslov (Talk | contribs)
Note: Starting from iPi Mocap Studio v4.3.0.
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unity editor.
Usage in Mocap Studio
Usage in Unity
Network settings
Technically, streaming protocol broadcasts UDP packets to a certain port on the local network. By default, the port used is 31455. You can change this value in Streaming Settings dialog which opens when you press a "gear" icon on Start Streaming button. If Mocap Studio and Unity are run on different PCs in the local network you may need to adjust firewall settings to allow traffic between them. I.e. allow outbound connections to the UDP port being used at a PC running Mocap Studio and allow inbound connections to that port at a PC running Unity.
