Streaming to Unity
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unity editor.
Usage in Mocap Studio
Usage in Unity
To get streaming data from iPi Mocap Studio in Unity you need to add several C# scripts to your Unity project. You can download them here (need link).
MocapStudioClient component reads data from the network. Add it to some game object which is always active. It has parameters:
- Port (int) - the number of an UDP port to listen for data from Mocap Studio. Should be equal to the value of UDP port set in the Streaming Settings in Mocap Studio. The default value is 31455.
CharacterAnimator component applies motion data to a character. Add this component to a character game object. Position is applied to this game object and rotations are applied to game objects corresponding to skeleton joints. This component has parameters:
- Root Joint (Transform) - set to a game object of character's joint (bone) to which the Hips joint of the actor model is mapped in motion transfer profile in Mocap Studio. Usually this is a root joint which is a child of the character game object.
Network settings
Technically, streaming protocol broadcasts UDP packets to a certain port on the local network. By default, the port used is 31455. You can change this value in Streaming Settings dialog which opens when you press a "gear" icon on Start Streaming button. If Mocap Studio and Unity are run on different PCs in the local network you may need to adjust firewall settings to allow traffic between them. I.e. allow outbound connections to the UDP port being used at a PC running Mocap Studio and allow inbound connections to that port at a PC running Unity.
