Streaming to Unity
Revision as of 05:17, 7 October 2019 by Vmaslov (Talk | contribs)
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unity editor.
Usage in Mocap Studio
Usage in Unity
To get data streamed by iPi Mocap Studio into Unity you need to use several C# scripts to your Unity project. You can download them from this link. This download contains necessary scripts under Scripts folder as well as a sample Unity project under Sample folder.
Scripts
  • Port (int) - the number of UDP port to listen for data from Mocap Studio. Should be equal to the value of UDP port set in the Streaming Settings in Mocap Studio. The default value is 31455.
    Tip: You may need to adjust firewall settings to allow incoming UDP connections to this port.
  • Mocap Data (MocapStudioClient) - set to a game object holding MocapStudioClient component.
Sample
  • Enable one of the characters in Unity.
  • Enter Play Mode.
  • Import corresponding FBX model as target character into iPi Mocap Studio. FBX model files can be found under Sample\Assets\Characters directory (for Robot Kyle dive deeper to Robot Kyle\Model).
  • Load corresponding motion transfer profile into iPi Mocap Studio. .iPiTransfer files with profiles also reside under Sample\Assets\Characters directory.
  • Press Start Streaming button.
  • Then the character in Unity will follow motions of the character in iPi Mocap Studio.
  • You didn't start streaming in iPi Mocap Studio.
  • Either MocapStudioClient or CharacterAnimator components are not enabled in Unity.
  • Target character set in iPi Mocap Studio doesn't match a character used in Unity.
  • iPi Mocap Studio and MocapStudioClient component are set to use different ports for streaming.
  • Your firewall is blocking data transfer from iPi Mocap Studio to Unity.
