Multiple Actors
The software supports multi-person tracking with the following limitations:
- Currently two or three actors tracking is available in the public release.
- To track multiple actors, at least 3 Sony PS Eye cameras per actor are required
- It's recommended to use 4 Sony PS Eye cameras per actor. Having more cameras minimizes actor's mutual occlusion and improves tracking reliability.
- For two actors you can use 3 Kinect sensors
- For simple dual actor actions when actors are rarely close to each other you can use 4 — 5 RGB cameras or even two depth sensors.
- Multi-person tracking is available only in Pro Edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
- All regular recommendations.
- Plus it's highly recommended to use different colors for clothing of different actors. It will minimize tracking errors.
For depth sensors:
- Only regular recommendations. No additional recommendations, because current version of iPi Mocap Studio doesn't use color data from depth sensors during tracking (color data is used only for visualization).
Cameras Configuration
The main requirement is to minimize self- and mutual occlusions of actors. In general, cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use minimum recommended number of cameras (or less) then all actions should be planned in such a way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to capture two actors handshake with just two depth sensors:
T-pose
It's convenient but not strongly required all actors to stay in T-pose at one and the same time as far from each other as possible (actors should be fully visible in maximum number of cameras).
Processing
- During project creation you will need to specify number of actors and then parameters of each actor:
- At the toolbar you will see buttons for switching between actors. Also you can switch by clicking on actor model in the 3D view port. Skin of "inactive" actor is grayed. Content of Actor tab is displayed for the active actor.
- For each actor:
- Roughly align actor's model with actor's images in all cameras using Move, Rotation and IK tools
- Adjust actor parameters if needed
- Click Analyze Actor Appearance button
- Correct actor's colors with the aid of Eye dropper if needed
- Click Refit Pose on Tracking tab.
- Repeat steps starting from 3 if needed
- Adjust Region-of-Interest, choose tracking settings on the Tracking tab and execute tracking
- After processing you can use regular procedures for Manual Clean-up and Automatic Refinement and Filtering.
Motion Controllers
You can use up to 3 motion controllers per actor for:
- left hand
- right hand
- head
File:Two actors motion controllers.png Attach to drop-down list |
Animation Export
Sample Video and Project
Here you can find sample videos and projects for three actors captured with ten Sony PS3 Eye cameras.
Calibration Sequence
| ↓ Download video file ↓ three_actors_10_cams_catch_and_throw_calib.iPiVideo 436 MByte |
| ↓ Download calibration file ↓ three_actors_10_cams_catch_and_throw_calib.iPiCalib 363 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select three_actors_10_cams_catch_and_throw_calib.iPiCalib file downloaded on the previous step.
- select three_actors_10_cams_catch_and_throw_calib.iPiVideo file downloaded before;
- the height of first camera over ground plane is about 1.41 m
Performance Sequence
| ↓ Download video file ↓ three_actors_10_cams_catch_and_throw_action.iPiVideo 333 MByte |
| ↓ Download project file ↓ three_actors_10_cams_catch_and_throw_action.iPiMotion 2.63 MByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select three_actors_10_cams_catch_and_throw_action.iPiMotion file downloaded on the previous step.
