Streaming to Unity
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unity editor.
Usage in Mocap Studio
Usage in Unity
To get data streamed by iPi Mocap Studio into Unity you need to add several C# scripts to your Unity project. You can download them from this link. This download contains necessary scripts under Scripts folder as well as a sample Unity project under Sample folder.
Scripts
Sample
- Enter Play Mode.
