Streaming to Unreal
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unreal editor or Unity editor.
Usage in Mocap Studio
Usage in Unreal
1. Install iPiMocapLiveLink plugin.
1.1. Download iPiMocapLiveLink plugin via links below.
Download: UE 4.25 - iPiMocap-Unreal-4-25.zip; UE 4.24 - iPiMocap-Unreal-4-24.zip
1.2. Unpack downloaded archieve into Engine\Plugins folder of you Unreal Engine installation. The folder iPiSoft will be created with subfolder iPiMocapLiveLink that will contain the plugin binaries and source code.
2.3. Enable iPiMocapLiveLink and LiveLink plugins.
