Streaming to Unreal
Revision as of 08:30, 11 December 2020 by Pavel (Talk | contribs)
--Pavel (talk) 08:58, 10 December 2020 (EST)
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unreal editor or Unity editor.
Usage in Mocap Studio
Usage in Unreal
Download: UE 4.25 - iPiMocap-Unreal-4-25.zip; UE 4.24 - iPiMocap-Unreal-4-24.zip
4. Instuctions for quick test. We used ThirdPerson project template.
4.1. Start streaming in iPi Mocap Studio as expained above. You need to use UE4 Mannequin Rig if you use standard Unreal character. You can import your own rig into iPi Mocap Studio and setup motion transfer profile if you use custom rig.
4.2. Connect to iPi Mocap Live Link source in Unreal Editor. Live Link Subject should appear in subjects list.
Note: Don't forget to start animation playback or live tracking session inside iPi Mocap Studio. Otherwise nothing will be streamed and subject will not show.
4.3. You can then use Live Link Pose blueprint to animate your character. Don't forget to select Character Live Link subject to feed in animation data.
