Environment and Actor Clothing
Environment
Space
For a multiple PlayStation Eye configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
iPi Desktop Motion Capture has an option of using T-shirt over long-sleeve shirt for actor clothing. The tracking quality should benefit from such clothing because the arms are distinguished better from the torso.
