Animation Streaming
Revision as of 05:02, 18 April 2022 by Andrew (Talk | contribs)
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unreal editor or Unity editor and integrate reading animation stream from iPi Mocap Studio into your games or applications created with Unreal or Unity.
Streaming to Unreal
Usage in Mocap Studio
Usage in Unreal
Download:
UE 5.6 - iPiMocap-Unreal-5-6.zip; UE 5.5 - iPiMocap-Unreal-5-5.zip; UE 5.4 - iPiMocap-Unreal-5-4.zip; UE 5.3 - iPiMocap-Unreal-5-3.zip; UE 5.2 - iPiMocap-Unreal-5-2.zip; UE 5.1 - iPiMocap-Unreal-5-1.zip; UE 5.0 - iPiMocap-Unreal-5-0.zip;
Instuctions for quick test.
MetaHuman
  • Start streaming in iPi Mocap Studio as expained above. You need to use MetaHuman rig.
  • Open Live Link streaming manager tab in Unreal Editor via Window > Live Link menu item (Window > Virtual Production > Live Link in UE5).
  • Connect to iPi Mocap Live Link source in Unreal Editor. iPi Mocap Live Link subject names Character should appear in subjects list.
Note: Don't forget to start animation playback or live tracking session inside iPi Mocap Studio. Otherwise nothing will be streamed and subject will not show.
  • You can then use Live Link Pose blueprint to animate MetaHuman character. Feed in output of Live Link Pose into Control Rig component in m_med_nnw_animbp. You can find it in Content > SampleMetaHumans > metahuman_004 > Male > Medium > NormalWeight > Body folder for male character or Content > SampleMetaHumans > metahuman_001 > Female > Medium > NormalWeight > Body for female character.
Note: Don't forget to select Character Live Link subject to feed in animation data.
Note: You can use other Live Link capabilities as well. Live Link Pose blueprint was just selected just for expample.
UE4 Mannequin (Standard Unreal Character)
  • Start streaming in iPi Mocap Studio as expained above. You need to use UE4 Mannequin rig if you use standard Unreal character. You can import your own rig into iPi Mocap Studio and setup motion transfer profile if you use custom rig.
  • You can then use Live Link Pose blueprint to animate your character.
Streaming to Unity
iPi Mocap Studio is capable of realtime streaming of character's pose over network. This can be used to preview captured motion in an actual game scene inside the Unity editor and integrate reading animation stream from iPi Mocap Studio into your games or applications created with Unity.
Usage in Unity
Download: iPiMocap-Unity.zip
To get data streamed by iPi Mocap Studio into Unity you need to add several C# scripts to your Unity project. Use the above download link to get them. This download contains necessary scripts under Scripts folder as well as a sample Unity project under Sample folder.
Scripts
  • Port (int) - the number of UDP port to listen for data from Mocap Studio. Should be equal to the value of UDP port set in the Streaming Settings in Mocap Studio. The default value is 31455.
    Tip: You may need to adjust firewall settings to allow incoming UDP connections to this port.
  • Mocap Data (MocapStudioClient) - set to a game object holding MocapStudioClient component.
Sample
  • Open SampleScene (from Assets/Scenes) if it didn't show up automatically when you opened the project.
  • Enable one of the characters in Unity.
  • Enter Play Mode.
  • Import corresponding FBX model as target character into iPi Mocap Studio. FBX model files can be found under Sample\Assets\Characters directory (for Robot Kyle dive deeper to Robot Kyle\Model).
  • Load corresponding motion transfer profile into iPi Mocap Studio. .iPiTransfer files with profiles also reside under Sample\Assets\Characters directory.
  • Press Start Streaming button.
  • Then the character in Unity will follow motions of the character in iPi Mocap Studio.
  • You didn't start streaming in iPi Mocap Studio.
  • Either MocapStudioClient or CharacterAnimator components are not enabled in Unity.
  • Target character set in iPi Mocap Studio doesn't match a character used in Unity.
  • iPi Mocap Studio and MocapStudioClient component are set to use different ports for streaming.
  • Your firewall is blocking data transfer from iPi Mocap Studio to Unity.
