Animation Export
- 1 Animation Export
- 2 Motion Transfer
- 3.1 MotionBuilder
- 3.2 3D MAX Biped
- 3.3 Maya
- 3.4 FBX
- 3.5 COLLADA
- 3.6 LightWave
- 3.7 SoftImage|XSI
- 3.8 Poser
- 3.9 DAZ 3D
- 3.10 Genesis 8
- 3.11 iClone 3
- 3.12 Valve Source Engine SMD
- 3.13 Valve Source Filmmaker
- 3.14 Blender
- 3.15 Cinema4D
- 3.16 Evolver
- 3.17 Second Life
- 3.18 Massive
- 3.19 IKinema WebAnimate
- 3.20 Jimmy|Rig Pro
Animation Export
- Select Export tab
- Select output file format
Motion Transfer
Other rigs
- Select Export tab
Multiple Target Bones
- Your character has separate bones for swing and twist rotation components
- Produce text or binary file
Genesis 8
- In DAZ Studio reset your character to T-pose.
- Export you DAZ character to FBX with default options.
iClone 3
