Streaming to Unreal
Revision as of 09:22, 22 July 2022 by Pavel (Talk | contribs)
Usage in Mocap Studio
Usage in Unreal
Download: UE 5.0 - iPiMocap-Unreal-5-0.zip; UE 4.27 - iPiMocap-Unreal-4-27.zip; UE 4.26 - iPiMocap-Unreal-4-26.zip; UE 4.25 - iPiMocap-Unreal-4-25.zip; UE 4.24 - iPiMocap-Unreal-4-24.zip
Instuctions for quick test.
MetaHuman
  • Start streaming in iPi Mocap Studio as expained above. You need to use MetaHuman rig.
  • Open Live Link streaming manager tab in Unreal Editor via Window > Live Link menu item.
  • Connect to iPi Mocap Live Link source in Unreal Editor. iPi Mocap Live Link subject names Character should appear in subjects list.
Note: Don't forget to start animation playback or live tracking session inside iPi Mocap Studio. Otherwise nothing will be streamed and subject will not show.
  • You can then use Live Link Pose blueprint to animate MetaHuman character. Feed in output of Live Link Pose into Control Rig component in m_med_nnw_animbp. You can find it in Content > SampleMetaHumans > metahuman_004 > Male > Medium > NormalWeight > Body folder for male character or Content > SampleMetaHumans > metahuman_001 > Female > Medium > NormalWeight > Body for female character.
Note: Don't forget to select Character Live Link subject to feed in animation data.
Note: You can use other Live Link capabilities as well. Live Link Pose blueprint was just selected just for expample.
UE4 Mannequin (Standard Unreal Character)
  • Start streaming in iPi Mocap Studio as expained above. You need to use UE4 Mannequin rig if you use standard Unreal character. You can import your own rig into iPi Mocap Studio and setup motion transfer profile if you use custom rig.
  • You can then use Live Link Pose blueprint to animate your character.
