Streaming to Unreal
Usage in Mocap Studio
Usage in Unreal
Download: UE 5.0 - iPiMocap-Unreal-5-0.zip; UE 4.27 - iPiMocap-Unreal-4-27.zip; UE 4.26 - iPiMocap-Unreal-4-26.zip; UE 4.25 - iPiMocap-Unreal-4-25.zip; UE 4.24 - iPiMocap-Unreal-4-24.zip
Instuctions for quick test.
MetaHuman
- Start streaming in iPi Mocap Studio as expained above. You need to use MetaHuman rig.
- Open Live Link streaming manager tab in Unreal Editor via Window > Live Link menu item (Window > Virtual Production > Live Link in UE5).
- You can then use Live Link Pose blueprint to animate MetaHuman character. Feed in output of Live Link Pose into Control Rig component in m_med_nnw_animbp. You can find it in Content > SampleMetaHumans > metahuman_004 > Male > Medium > NormalWeight > Body folder for male character or Content > SampleMetaHumans > metahuman_001 > Female > Medium > NormalWeight > Body for female character.
- Note: Don't forget to select Character Live Link subject to feed in animation data.
UE4 Mannequin (Standard Unreal Character)
- You can then use Live Link Pose blueprint to animate your character.
