Calibration Definition AI
Revision as of 13:04, 31 October 2024 by Pavel (Talk | contribs)
Calibration is a process of computing accurate camera positions and orientations from a video. This step is essential and required for multi-camera system setup.
Calibration can be done by user waving a small glowing object called marker (for color/color+depth cameras). Novel AI-based pose estimation algorithms allow to use AI-detected joint positions instead of glowing object (flashlight), that makes the process simpler.
