Multiple Actors
Revision as of 05:38, 1 November 2014 by Pavel (Talk | contribs)
Pro Edition, supports multi-person tracking with the following limitations:
  • Currently only two actors tracking is available in the public release.
    • Tracking of more than two actors will become possible when we implement 12 cameras support. More cameras is needed minimize actor's mutual occlusion.
  • At least 5 Sony PS Eye cameras or 3 Kinect sensors are required to track multiple actors.
  • It's recommended to use 6 — 8 Sony PS Eye cameras to track multiple actors.
  • For simple actions when actors are rarely close to each other you can use 4 — 5 Sony PS Eye cameras or even two Kinect sensors.
  • For single depth sensor and for 3 web cameras multi-person tracking is not enabled.
  • Multi-person tracking is available only in Pro Edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
For depth sensors:
Cameras Configuration
The main requirement is to minimize self- and mutual occlusions of actors. In general, 5 — 8 cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use less cameras then all actions should be planned in such a way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to capture two actors handshake with just two depth sensors:
Scene Configuration Example
T-pose
T-poses of Actors
Processing
How many actors?
First actor parameters
Second actor parameters
Active actor on UI
  • For each actor:
Tracking Tab Controls
Motion Controllers
  • left hand of the first actor
  • right hand of the first actor
  • head of the first actor
  • left hand of the second actor
  • right hand of the second actor
  • head of the second actor
Or any subset of these items.
Animation Export
Export
Demo
