Environment and Actor Clothing
Revision as of 17:10, 3 November 2014 by Pavel (Talk | contribs)
Environment
Space
For a multiple PlayStation Eye configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
