Sample Video and Project (four PS Eye)
Revision as of 18:22, 3 November 2014 by Andrew (Talk | contribs)
Calibration Sequence
Here you can download sample calibration video file captured with the aid of four PS Eye cameras and appropriate iPiCalib project which is result of processing in iPi Mocap Studio:
Download video file
tutorial_4cam_calibration.iPiVideo
252 MByte
 iPiVideoIcon-128.png         iPiCalibIcon-128.png Download calibration file
four_ps_eyes_calibration.iPiCalib
300 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four_ps_eyes_calibration.iPiCalib file downloaded on the previous step.
    • select four_ps_eyes_calibration.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate button;
      • the height of first camera over ground plane is about 1.10 m
Performance Sequence
Here you can download sample performance video file captured with the aid of four PS Eye cameras and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
Download video file
four_ps_eyes_action.iPiVideo
59 MByte
 iPiVideoIcon-128.png         iPiMotionIcon-128.png Download project file
four_ps_eyes_action.iPiMotion
500 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four_ps_eyes_action.iPiMotion file downloaded on the previous step.
    • select four_ps_eyes_action.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: four_ps_eyes_calibration.iPiCalib
      • Gender = Male
      • Height = 1.99 m
      • Clothing model = Long-sleeve shirt
    • then you can process the video.
Exported Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Blender
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Engineer Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
