Hand Keyframing
Basics
- Manually edit one of the finger bones with the Rotate tool
- Click Insert Key Frame for Right Hand or Insert Key Frame for Left Hand button on timeline toolbar (1)
- Click Insert Key Frame for Right Hand or Insert Key Frame for Left Hand menu item from the context menu of the timeline (2)
- Paste a pose data containing the finger bones rotations from the clipboard
- Going to the last frame (same as double click)
- Setting one of the predefined poses like fist, relaxed etc. as well as recently used poses from files
- Deleting this key frame
Advanced
Managing hand pose library
You may add your own hand poses to the list of standard poses present in the context menu for a keyframe. For that, you just need to save the hand pose somewhere in a file. 10 most recently saved/loaded/applied pose files are listed in the context menu for corresponding hand. To access older poses, use Edit > Load Pose from File to Clipboard menu item — the hand pose will be automatically placed to the context menu (replacing the oldest one from 10 items).
- Setup the needed pose for fingers with the Rotate tool (or copy from another hand)
- Select the appropriate hand bone (RHand or LHand)
- Hit Edit > Copy Pose of Selected Bone's Children to copy the pose of fingers to the clipboard
- Hit Edit > Save Pose to File from Clipboard to save the pose in a file
See also the video tutorial.
Transferring a pose from one hand to another
- When using the Paste Pose within ROI command, the finger bones are not touched. Use direct manipulation with hand key frames to massively edit finger poses.
- When editing the fingers pose in the middle of an existing key frame, it is automatically split in two parts. When editing the pose in the last frame of a key frame, its key pose is changed, and no new key frame is created.
- Finger poses for the whole animation are fully recomputed based on the key frames when opening a project. If you see some "glitches" with finger poses (they do not look like poses driven by the key frames), just reopen the project.
