Sample Video and Project (four PS Eye)
Revision as of 11:40, 30 December 2014 by Andrew (Talk | contribs)
Here you can find sample videos and animations captured with the aid of four Sony PS3 Eye cameras.
Calibration Sequence
four_ps_eyes_calibration.iPiVideo
252 MByte
four_ps_eyes_calibration.iPiCalib
300 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four_ps_eyes_calibration.iPiCalib file downloaded on the previous step.
    • select four_ps_eyes_calibration.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate button;
      • the height of first camera over ground plane is about 1.10 m
Performance Sequence
four_ps_eyes_action.iPiVideo
59 MByte
four_ps_eyes_action.iPiMotion
500 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four_ps_eyes_action.iPiMotion file downloaded on the previous step.
    • select four_ps_eyes_action.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: four_ps_eyes_calibration.iPiCalib
      • Gender = Male
      • Height = 1.99 m
      • Clothing model = Long-sleeve shirt
    • then you can process the video.
Exported Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Blender
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Engineer Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
