Sample Video and Project (single depth sensor)
Here you can find sample videos and animations captured with the aid of single MS Kinect 2 depth sensor.
"Jumps" Sequence
Sample video file with jump movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ single_kinect2_jumps.iPiVideo 80 MByte |
| ↓ Download project file ↓ single_kinect2_jumps.iPiMotion 580 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_jumps.iPiMotion file downloaded on the previous step.
- select single_kinect2_jumps.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
- then you can process the video.
Exported "Jumps" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
- Blender
"Catch and Throw" Sequence
Sample video file with catch-and-throw movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ single_kinect2_catch_and_throw.iPiVideo 105 MByte |
| ↓ Download project file ↓ single_kinect2_catch_and_throw.iPiMotion 810 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_catch_and_throw.iPiMotion file downloaded on the previous step.
- select single_kinect2_catch_and_throw.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
Exported "Catch and Throw" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
- Blender
