Sample Video and Project (single depth sensor)
Revision as of 15:59, 30 December 2014 by Andrew (Talk | contribs)
Here you can find sample videos and animations captured with the aid of single MS Kinect 2 depth sensor.
"Jumps" Sequence
Sample video file with jump movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_jumps.iPiVideo
80 MByte
single_kinect2_jumps.iPiMotion
580 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_jumps.iPiMotion file downloaded on the previous step.
    • select single_kinect2_jumps.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
    • then you can process the video.
Exported "Jumps" Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Blender
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Engineer Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
"Catch and Throw" Sequence
Sample video file with catch-and-throw movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
single_kinect2_catch_and_throw.iPiVideo
105 MByte
single_kinect2_catch_and_throw.iPiMotion
810 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select single_kinect2_catch_and_throw.iPiMotion file downloaded on the previous step.
    • select single_kinect2_catch_and_throw.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "Catch and Throw" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
  • Blender
