Sample Video and Project (two ASUS Xtions)
Revision as of 15:26, 30 December 2014 by Andrew (Talk | contribs)
Here you can find sample videos and animations captured by two ASUS Xtion Live depth sensors.
Calibration Sequence
two_depth_sensors_calibration.iPiVideo
103 MByte
two_depth_sensors_calibration.iPiCalib
83 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_depth_sensors_calibration.iPiCalib file downloaded on the previous step.
    • select two_depth_sensors_calibration.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate Based on Board button;
    • after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
    • now you can visually check the quality of the resulted point cloud.
Performance Sequence
two_depth_sensors_action.iPiVideo
50 MByte
two_depth_sensors_action.iPiMotion
530 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_depth_sensors_action.iPiMotion file downloaded on the previous step.
    • select two_depth_sensors_action.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: two_depth_sensors_calibration.iPiCalib
      • Gender = Male
      • Height = 1.76 m
    • then you can process the video.
More Samples
Sample videos and animations captured by two MS Kinect 2 sensors can be found on the following page: Sample Video and Project (two depth sensors)
