Sample Video and Project (two depth sensors)
Here you can find sample videos and animations captured by two MS Kinect 2 depth sensors with the aid of Distributed Recording.
Calibration Sequence
| ↓ Download video file ↓ two_kinects2_calibration.iPiVideo 339 MByte |
| ↓ Download calibration file ↓ two_kinects2_calibration.iPiCalib 99 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_calibration.iPiCalib file downloaded on the previous step.
- select two_kinects2_calibration.iPiVideo file downloaded before;
- switch to Calibration tab and push Calibrate Based on Light Marker button;
- after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
- now you can visually check the quality of the resulted point cloud.
"Walk" Performance Sequence
Sample performance video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ two_kinects2_walk.iPiVideo 122 MByte |
| ↓ Download project file ↓ two_kinects2_walk.iPiMotion 450 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_walk.iPiMotion file downloaded on the previous step.
- select two_kinects2_walk.iPiVideo file downloaded before;
- choose Action project type;
- choose the following file as scene parameters: two_kinects2_calibration.iPiCalib
- Gender = Male
- Height = 1.75 m
- then you can process the video.
Exported "Walk" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
- Blender
"Side Running" Performance Sequence
Sample performance video file with side-running movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
| ↓ Download video file ↓ two_kinects2_side_running.iPiVideo 203 MByte |
| ↓ Download project file ↓ two_kinects2_side_running.iPiMotion 695 KByte |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_side_running.iPiMotion file downloaded on the previous step.
- select two_kinects2_side_running.iPiVideo file downloaded before;
- Gender = Male
- Height = 1.75 m
Exported "Side Running" Animation
- Default iPi Rig
- Motion Builder
- 3ds Max Biped
- Blender
More Samples
Sample videos and animations captured by two ASUS Xtion Live sensors can be found on the following page: Sample Video and Project (two ASUS Xtions).
