Sample Video and Project (two depth sensors)
Revision as of 16:35, 30 December 2014 by Andrew (Talk | contribs)
Here you can find sample videos and animations captured by two MS Kinect 2 depth sensors with the aid of Distributed Recording.
Calibration Sequence
two_kinects2_calibration.iPiVideo
339 MByte
two_kinects2_calibration.iPiCalib
99 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_calibration.iPiCalib file downloaded on the previous step.
    • select two_kinects2_calibration.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate Based on Light Marker button;
    • after calibration is performed, hide background using View > Hide Background menu item and turn on View > Show Depth from All Sensors item;
    • now you can visually check the quality of the resulted point cloud.
"Walk" Performance Sequence
Sample performance video file with walking movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
two_kinects2_walk.iPiVideo
122 MByte
two_kinects2_walk.iPiMotion
450 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_walk.iPiMotion file downloaded on the previous step.
    • select two_kinects2_walk.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: two_kinects2_calibration.iPiCalib
      • Gender = Male
      • Height = 1.75 m
    • then you can process the video.
Exported "Walk" Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Blender
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Engineer Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
"Side Running" Performance Sequence
Sample performance video file with side-running movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
two_kinects2_side_running.iPiVideo
203 MByte
two_kinects2_side_running.iPiMotion
695 KByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_side_running.iPiMotion file downloaded on the previous step.
    • select two_kinects2_side_running.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "Side Running" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
  • Blender
"Complex" Performance Sequence
Sample performance video file with different rather complex movements and appropriate iPiMotion project which is result of processing in iPi Mocap Studio:
two_kinects2_complex.iPiVideo
702 MByte
two_kinects2_complex.iPiMotion
3.6 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select two_kinects2_complex.iPiMotion file downloaded on the previous step.
    • select two_kinects2_complex.iPiVideo file downloaded before;
      • Gender = Male
      • Height = 1.75 m
Exported "Complex" Animation
  • Default iPi Rig
  • Motion Builder
  • 3ds Max Biped
  • Blender
More Samples
Sample videos and animations captured by two ASUS Xtion Live sensors can be found on the following page: Sample Video and Project (two ASUS Xtions).
