iPi Biomech Add-on
Revision as of 09:15, 19 March 2015 by Vmaslov (Talk | contribs)
  • Export of point cloud from multiple Kinect sensors for animation or research
  • Sports motion analysis
Note: iPi Biomech Add-on requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. 30-days free trial provided.
Glossary
Bone
skeleton segment between two joints
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Linear coordinate system
  • Absolute (relative to ground)
    • Axes are shown by selecting Move tool;
    • Y axis is vertical
    • XZ plane is floor
    • Center and X, Z axes directions are automatically set during calibration
    • Recenter Coordinates on Character button on Scene tab before tracking will align coordinate system with actor in T-pose
      • Y is vertical axis passing through center of mass
      • XZ plane is floor
      • X is directed along left arm in T-pose
  • Relative to center of mass
    • Axes directions are the same as Absolute coordinate system described above;
    • Center is in the actor model's center of mass
  • Relative to parent joint
    • Center coincides with the coordinates of the parent joint
Angular coordinate system
Euler angles system
Unit
Measurement unit of physical quantity (feet or meter, etc.)
iPi Biomech Add-on requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. You can order your license here, or activate 30-days free trial. Follow the steps below to start working with iPi Biomech Add-on
  1. Switch to Biomech tab.
  2. Press Activate button
Note: If you do not have iPi Mocap Studio license key, you can order it here or activate 30-days free trial. If your Studio trial has expired, you will not be able to export biomech data as well as animation. But you can still plot biomech data.
Select Data for Analysis
  1. Select bones
    Note: On the top of the list you can see "special" bones — Center of mass, Center of mass projection to the ground. The rest of the list are the bones from the internal iPi rig.
    • (2) You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
    • (3) You can select all bones by clicking to the checkbox in the header. Fingers will be included only if the hand bone is expanded.
    • (4) You can change bones listbox height using splitter at the bottom.
  8. Select Euler angles system
Plot Data
Export Motion Data
  3. Select export option:
Export Point Cloud
  5. Select export format
  6. Press Export Selected Data button
  7. Select export option:
    • One point cloud from current frame: export single point cloud from the current frame to file
    • All frames of ROI: export multiple point clouds (one point cloud from each frame of the Region-of-Interest) to single or multiple files depending of export format
Import of Point Cloud to 3d Packages
Point cloud data can be useful as video reference in 3d packages like 3ds Max, Maya and others.
  • Krakatoa PRT format is recognized by Krakato PRT Loader for 3ds Max and Maya. It can load to multiple frames from multiple files.
  • OBJ format is natively supported in 3ds Max
  • PLY format can be imported to Max with this free plugin
Biomech Export Profile
