Animation Export
- 1 Animation Export
- 2 Motion Transfer
Animation Export
- Select 'Export' tab
- Select rig or import model you want to transfer motions to (see details on motion transfer below)
- Select output file format
Motion Transfer
Other rigs
- Humanik Maya 2012 Part 6
