Animation Export
- 1 Animation Export
- 2 Motion Transfer
Animation Export
- Select 'Export' tab
- The motions will be automatically transferred to selected rig (except Default iPi Rig, that does not require motion transfer; see details on motion transfer below)
- Select output file format
Motion Transfer
Other rigs
- Humanik Maya 2012 Part 6
