Animation Export
Revision as of 04:00, 6 April 2015 by Vmaslov (Talk | contribs)
Animation Export
  1. Select Export tab
  4. Select output file format
Motion Transfer
Other rigs
Step 5
Step 5
Step 5
Step 6
700px
