Animation Export
- 1 Animation Export
- 2 Motion Transfer
Animation Export
- Select Export tab
- Select output file format
Motion Transfer
Other rigs
- Select Export tab
- Select 3ds Max Biped rig on Export tab and export animation to BVH or FBX.
- Humanik Maya 2012 Part 6
