Animation Export
Revision as of 04:37, 7 April 2015 by Pavel (Talk | contribs)
Animation Export
  1. Select Export tab
  4. Select output file format
Motion Transfer
Other rigs
  • What version of FBX format to use, ranging from 6.1 (2010 product line) to 7.4 (2015 product line)
  • Produce text or binary file
  1. In DAZ Studio reset your character to T-pose and correct feet positions as shown on picture below.
  2. Export you DAZ character to BVH with default options.
  3. Import your DAZ character skeleton into iPi Mocap Studio. Your animation will be transferred to your DAZ character.
  4. Export your animation to BVH format.
  5. Import exported BVH to DAZ Studio.
Note: You can use DAZ character in COLLADA (.dae) format for preview, but it is strongly recommended that you use DAZ character in BVH format for motion transfer. DAZ3D has a problem with COLLADA (.dae) format: DAZ3D Studio does not export all bones into COLLADA (.dae). In particular, the following bones are not exported: eyeBrow, bodyMorphs. DAZ3D Studio does not use bone names when importing motions; instead, DAZ3D Studio just takes rotations from the list of angles as though it was a flat list with exactly the same positions as in DAZ3D internal skeleton. As the result, when you transfer the motion to a COLLADA character and import it back into DAZ3D, the motion will look wrong. iPi Mocap Studio displays a warning about this. To avoid this problem, import your DAZ target character in BVH format - DAZ3D Studio is known to export characters in BVH format correctly (with all bones).
Tip: You can improve accuracy of motion transfer by doing some additional preparation of your DAZ 3D skeleton in BVH format. For DAZ 3D Michael 4.0 and similar characters, you may need to clamp thigh joint rotation to zero to avoid unnatural leg bending. For DAZ 3D Victoria 4.0, you may need to adjust foot joint rotation to change the default “high heels“ foot pose to a more natural foot pose.
Step 5
Step 5
Step 5
Step 6
700px
