Animation Export
- 1 Animation Export
- 2 Motion Transfer
Animation Export
- Select Export tab
- Select output file format
Motion Transfer
Other rigs
- Select Export tab
- Humanik Maya 2012 Part 6
- What version of FBX format to use, ranging from 6.1 (2010 product line) to 7.4 (2015 product line)
- Produce text or binary file
