Checking Sensor Calibration for Depth Sensors
Checking Sensors Calibration
Frequent cause of tracking errors is incorrect sensors calibration, that can be result of moving sensor(s) after calibration recording. You can use T-pose to detect this problem:
- Select frame with T-Pose
- Select View > Show Depth from All Sensors menu item
- Select View > Color Point Cloud with RGB Data menu item (if available)
- If any sensor was shifted, point clouds from different sensor will not match properly and you'll see weird shifts in point clouds (see screenshots)
