iPi Automation Add-on
- Switch to Integration tab.
- Press Activate button
Using iPi Integration Add-on
Command Syntax Reference
Commands are strings based on JSON syntax. The response is also JSON string.
// Request { "command":<command_name_string>, ["arguments":<arguments_list_json_string>] } // Response { "success":true|false, ["result":<result_json_string>] }
iPi Recorder Commands
// Request { "command":"get-app-info" } // Response { "success":true|false, "result": { "appName":<application_name_string>, "appVersion":<application_version_string> } }
EXAMPLES
// Request { "command":"get-app-info" } // Response { "success":true, "result": { "appName":"iPi Recorder 3", "appVersion":"99.876.543.210" } }
set-recorder-props command sets properties for setup, background and recroding stages.
| Parameter Name | Type | Required | Allowed Values | Description |
| Arguments | ||||
"None" "Background subtraction" "JPEG" |
Setting RGB video compression mode |
JPEG quality for JPEG compression |
Setting depth compression mode |
| globalDeviceProps | JSON object | optional |
Device-specific list of properties visible in “SHARED SETTINGS” section of “SETUP” stage | |
| Result | ||||
| Empty result | ||||
EXAMPLES
// Request { "command":"set-recorder-props", "arguments": { "colorCompression":"jpeg", "globalDeviceProps": { "PlayStation Eye: Darkening for calibration":"None" }, "hideBackgroundWhenRecording":true, "recordingStartDelay":0, "videoMode":"640x480 color @ 50Hz" } } // Response { "success":true }
