iPi Automation Add-on
- Switch to Integration tab.
- Press Activate button
Using iPi Integration Add-on
// Request for command without arguments { "command": "<command_name_string>" } // Request for command with arguments { "command": "<command_name_string>", "arguments": { <arguments_list_json_string> } } // Simple response in case of success { "success": true } // Response including command result field in case of success { "success": true, "result": { <result_json_string> } } // Response in case of error { "success": false, "error": "<error_message_string>" }
iPi Recorder Commands
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "open-studio", "arguments": { "filePath": "D:\iPiMocap\test_record.iPiVideo" } } // Response { "success":true }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "exit" } // Response { "success":true }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "get-app-info" } // Response { "success":true }
| Arguments | ||||
For RGB cameras: |
Setting screen layout. |
Valid file path |
"None" |
JPEG quality for JPEG compression. |
| Result | ||||
| Empty result | ||||
// Request { "command":"set-recorder-props", "arguments": { "colorCompression":"jpeg", "globalDeviceProps": { "PlayStation Eye: Darkening for calibration":"None" }, "hideBackgroundWhenRecording":true, "recordingStartDelay":0, "videoMode":"640x480 color @ 50Hz" } } // Response { "success":true }
