iPi Automation Add-on
- Switch to Integration tab.
- Press Activate button
Using iPi Integration Add-on
iPi Recorder Commands
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "open-studio", "arguments": { "filePath": "D:\iPiMocap\test_record.iPiVideo" } } // Response { "success": true }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Array of JSON objects, each representing recording device. Fields of list items: | ||||
| kind | string | mandatory | camera depth-sensor microfon |
Device type. |
Device selected status. |
Device filed status. |
// Request { "command": "refresh-device-list" } // Response { "success":true, "result": [ { "kind": "camera", "model":"PlayStation Eye", "id":"\\\\?\\usb#vid_1415&pid_2000&mi_00#7&2ed872d7&0&0000#{4cff9941-d72f-4951-9291-03d8fc97fe30}", "selected":false, "failed":false }, { "kind": "depth-sensor", "model": "Kinect 2 for Windows", "id": "Default Kinect 2", "selected": true, "failed":true, "error": "Is not available" }, { "kind": "microphone", "model": "USB Camera-B4.04.27.1", "id": "Microphone (USB Camera-B4.04.27 [VID=-1; PID=-1; Driver=256; Channels=2; Supports=WAVE_FORMAT_11M08, ...]", "selected": false, "failed": false } ] }
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "evaluate-backgorund", "arguments": { "duration": 3, "startDelay": 1 } } // Response { "success": true }
| Arguments | ||||
For RGB cameras: |
Setting screen layout. |
Valid file path |
"None" |
JPEG quality for JPEG compression. |
| Result | ||||
| Empty result | ||||
