iPi Automation Add-on
- Switch to Integration tab.
- Press Activate button
Using iPi Integration Add-on
iPi Recorder Commands
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
// Request { "command": "open-studio", "arguments": { "filePath": "D:\iPiMocap\test_record.iPiVideo" } } // Response { "success": true }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| kind | string | mandatory | camera depth-sensor microfon |
Device type. |
Device selected status. |
Device filed status. |
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
Duration of the recording. |
// Request { "command": "start-recording", "arguments": { "filePath": "D:\iPiMocap\test_record.iPiVideo", "startDelay": 1 } } // Response { "success": true } // Event { "event": "recording-stopped", "arguments": { "success": true, "cancelled": false, "filePath": "D:\iPiMocap\test_record.iPiVideo", "fileSize": 39975560, "duration": "00:00:04.0155425", "frameCount": 197 } }
stop-recorder command stops recording.
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
// Request { "command": "stop-recording" } // Response { "success": true } // Event { "event": "recording-stopped", "arguments": { "success": true, "cancelled": false, "filePath": "D:\iPiMocap\test_record.iPiVideo", "fileSize": 39975560, "duration": "00:00:04.0155425", "frameCount": 197 } }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Device type. |
Device failed status. |
// Request { "command": "refresh-device-list" } // Response { "success":true, "result": [ { "kind": "camera", "model": "PlayStation Eye", "id": "\\\\?\\usb#vid_1415&pid_2000&mi_00#7&2ed872d7&0&0000#{4cff9941-d72f-4951-9291-03d8fc97fe30}", "selected": false, "failed": false, "statistics": { "frameRate":50.0, "frameDropsPerSecond":0.0, "badFramesPerSecond":0.0, "totalFrameDrops":0, "totalBadFrames":0 } }, { "kind": "microphone", "model": "USB Camera-B4.04.27.1", "id": "Microphone (USB Camera-B4.04.27 [VID=-1; PID=-1; Driver=256; Channels=2; Supports=WAVE_FORMAT_11M08, ...]", "selected": false, "failed": false, "statistics": { "frameRate":50.0, "frameDropsPerSecond":0.0, "badFramesPerSecond":0.0, "totalFrameDrops":0, "totalBadFrames":0 } } ] }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Selected RGB video mode. |
Possible videoMode values. |
Selected audio mode. This field is included into the response, if microphone selected. |
For RGB cameras: |
Selected screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
// Request { "command": "get-recorder-props" } // Response { "success": true, "result": { "videoMode": "640x480 color @ 50Hz", "videoModeList": [ "640x480 color @ 60Hz", "640x480 color @ 50Hz", "640x480 color @ 40Hz", "640x480 color @ 30Hz", "640x480 color @ 25Hz", "320x240 color @ 60Hz", "320x240 color @ 50Hz", "320x240 color @ 37Hz", "320x240 color @ 30Hz" ], "screensInRow": 1, "screenLayout": "Color", "screenLayoutList": [ "Color" ], "globalDeviceProps": { "PlayStation Eye: Darkening for Calibration": "None", "PlayStation Eye: Darkening for Calibration/List": [ "None", "Darkening", "Extra Darkening" ] }, "backgroundEvaluationStartDelay": 5, "backgroundEvaluationDuration": 2, "showEvaluatedBackground": false, "recordingStartDelay": 1, "hideBackgroundWhenRecording": true, "destinationFilePath": "D:\iPiMocap\<time stamp>.iPiVideo", "colorCompression":"Jpeg", "jpegQuality":100, "depthCompression":"BackgroundSubtraction" } }
| Arguments | ||||
For RGB cameras: |
Setting screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
